 Need help choosing... >
Old 12-04-2007 | 01:58 PM
Charlie P.'s Avatar
Default RE: Need help choosing...
At high or low throttle?
Out of fuel, over rich, over lean, air leak, overheated in cowl, bad fuel, hitting the ground.
Old 12-04-2007 | 02:27 PM
At low trottle (idle), even after some time at full trottle, the engine still "cold", he never overheat, and my fuel tank was nearly full, and I hit the ground (after the fence) because my engine died.
I've check all setting (airbleed, high speed neddle valve), I've check the glow plug, the fuel tubing, I use cool power 10% (as 2 of my friends, and their engines run great), so i have no idea!
Old 12-04-2007 | 02:38 PM
edmoor's Avatar
i will tell you this.....you get yourself a hobbico electrastar ep. its tri gear. its a 60 size model. i have had more fun with this airplane......it will do aerobatics if ya want....yet its a very forgiving airplane.....i fly alot in wind......its a very nicely built airplane. i even mounted a digital camera on it......here is one. i chose the rtf model.
Old 12-04-2007 | 06:53 PM
Just to let you know, i've ordered a super stick 40 (value serie) from H9, i'll put my 65la on it, this should be an interesting combo!!!
SDG666
