RCU Forums - View Single Post - Testing a CX-2 4in1
Old 12-03-2007 | 09:58 AM
BryFlyGuy67's Avatar
BryFlyGuy67
Default RE: Testing a CX-2 4in1
If you have a volt meter, you can pull the plugs for the motors and then test voltage at the pins of the 4-in-1. I can't tell you what it should be, but:
(a) I do remember someone (maybe mrasmm) posting the correct voltages around here a while back. Do a search.
(b) If you post the voltage readings you got, I am sure mrasmm will be around soon and he can tell you if they are correct.
If you don't have a multi-meter, you really need to get one. If none of the above is an option, then I think that you would have to buy a new one and see if it works better. [&o]
