ORIGINAL: DocYates
Todd,
With the five bulb EVO system, can I make two of the whites strobe with the other in a fixed position? Are these programmable? What voltage doe they use?
Thanks for the link.
Tommy
Tommy,
With the Evo 5 you can select which channels are beacon and which are fixed in any quantity, ie: 2 beacon, 3 position ; 3 beacon 2 position ect... You can also select lights to be controlled by the TX if desired. You also have the choice of 16 variations of flash sequence in the beacon settings. Extremely high quality modules that are fully programmable.
The Multilight mini module offers up to 8 channels, two of which can be controlled by the TX if desired.
We also have rotating beacons in red and white in a small and large size.
These modules are designed to run on 4.8 to 6V and are compatible with SMT or Luxeon bulbs.
Todd
