ORIGINAL: Rfabbre
Looking for advise about cutting a spinner out to accept a larger prop. I have used a mototool with a grinder several times, but every time the aluminum clogs the grinder. Is there a better way?
I use a metal carbide cutting tool, these can be found at most stores that carry dremel products. Best discription I can give is looks like a gear on a 1/8 metal rod, about 3/8 in. in dia.
