RE: fuel fill - t fitting
T fitting on a glow engine does not work too well, as the fill will seriously flood the engine. It is used successfully on gas engine set ups because the gas carburator does not freely pass through the fuel as the glow carb does. If you use a two line set up, it's best to fill and defuel by removing the line from the carb nipple. If this is not feasable, then go to a three line system.
