CX2 VS Lama V4
I know most feel the CX2 is better, but my question is You can get a lama v4 with turbo up grade, 900mah extra battery, 6sets of extra blades plus extra landing gear. All this extra comes to be about 3 dollars more then the 189.00 for the CX2. Does the CX2 fly better and hover better then the Lama V4 to off set the cost. The Turbo up grade gives 3cm longer shaft w/metal hub, metal swatch plate, metal grip set, and metal center holder. All this is suppose to greatly improve speed and control of the Lama will it then put it on par or even better then the CX2. Thanks
