CX2 VS Lama V4
I know most feel the CX2 is better, but my question is You can get a lama v4 with turbo up grade, 900mah extra battery, 6sets of extra blades plus extra landing gear. All this extra comes to be about 3 dollars more then the 189.00 for the CX2. Does the CX2 fly better and hover better then the Lama V4 to off set the cost. The Turbo up grade gives 3cm longer shaft w/metal hub, metal swatch plate, metal grip set, and metal center holder. All this is suppose to greatly improve speed and control of the Lama will it then put it on par or even better then the CX2. Thanks
I only own a cx2 and its my first heli, but the lama seems like the "better bang for the buck" over-all. Its just SO UGLY [:'(]! I am thinking of buying a Lama for my brother inlaw for x-mas
From what I understand the major difference is in the radio. But if I only fly indoors and solo will the radio difference matter then? Also which would be the better frequency 35 or 72??
since you live in the US, it's only legal to use 72mhz =)
yeah, basically the difference between the two for the cx2 is the dsm2 Tx, the warranty and the LHS support as far as help and parts, the lama's basically have price going for them, about 1/2 =)
