RCU Forums - View Single Post - need help
Thread: need help
Old 12-05-2007 | 10:47 AM
twomanytoys
Default RE: need help
You can use the 2 speed if you installed a better engine and smaller gearing like the 13/18. Stock gearing is too tall to pull 2nd gear and letting it shift into second while in grass will also over work the stock vx and make it overheat. The 13t single is way faster than the 2 speed. It will help the engine reach its max rpm's alot easier.
