I ran out of jb weld here. I cannot get it here so I redid the tubing with 1/8 aluminum tubing this time. And I used alumaloy (
www.alumaloy.net )to weld it , I use a propane torch and heat it up and it is gust like solder for aluminum, it works grate . I tried the cut down prop it sure spooled up faster and had a better vertical for the short flight I had . I also ripped off the monocote in flight under the plane between the fire wall and the front of the wing. a miner repair. This time I did i ran the smoke pump and no leaks. as for the glitching I also got a smart fly power expander pro , even with the signal Full RF filtering
I still got glitching. Since the new radio no more problems.
