RCU Forums - View Single Post - Does anyone see a problem with this?
Old 12-06-2007 | 01:23 AM
Campgems
Default RE: Does anyone see a problem with this?
I guess I'm used to the four strokes setting an inch and a half off the firewall. You will be OK, but use the retainers I mentioned before. Let me know if you need a photo of what I'm talking about.
A couple points, don't tighten the bung (lid) to tight as those ARF tanks tend to split open some times. Also, make sure you don't have sharp edges on the brass tubing that could cut the lines. You will not have much luck trying to replace the lines later without pulling the tank. Use some wet or dry and round the edge just a bit. Then make sure you rinse the tubes out with some fuel to get any grit out that may have collected, then install them into the tank.
One last thing, I usually use a short, 1/4' to 1/2" piece of fuel line on the vent tube inside the tank. Just a bumper to speak on the tube so it doesn't have a chance to abrade the top of the tank.
Don
