Fuel filter for DA 100 ?
I use a filter I got from the local lawnmower shop. It has a paper element. Make sure the ends will fit into the tubing you use. I use EasyFlex tubing from AeroTrend. The stuff works great. I also use tie-wraps on all my connections to be sure that nothing comes loose.
