Fuel filter for DA 100 ?
Old 04-05-2003 | 03:21 AM
Default Fuel filter for DA 100 ?
Hey guys I just picked up my new DA 100 and they recommend using an inline fuel filter which one is the best to get and were can I get one .Thanks Randy
Old 04-05-2003 | 03:24 AM
I use a filter I got from the local lawnmower shop. It has a paper element. Make sure the ends will fit into the tubing you use. I use EasyFlex tubing from AeroTrend. The stuff works great. I also use tie-wraps on all my connections to be sure that nothing comes loose.
Old 04-05-2003 | 02:06 PM
My Feedback: (8)
hangar 9 makes a great filter,it's made of aluminum with a removable screen for easy cleaning and rubber o rings for sealing. It's also a larger diameter so it works great for gas engines,no fuel restriction.
Old 04-05-2003 | 02:33 PM
Big_Bird's Avatar
If you start with a clean tank and fuel lines in your plane you don't need a filter. Get one of the automotive type fuel filters and filter the outlet of your gas can. I've done this for years and never had any trouble with trash clogging the carburetor screen.
Ken
Old 04-05-2003 | 03:05 PM
Using the HP filter. Works great. I use a filter on everything. Its amazing how a little piece of dirt, grass, silicone, plastic...... can get stuck in that little needle valve!
