ORIGINAL: kcollier
Hey Guys,
I'm putting together my shopping list with DL50 at the top. Just wanted to know what size spinner adapter/nut is needed
to use with the Dave Brown standard 3.25 aluminum spinner or and any suggestions for a spinner / adapter combo?
Keith
Hi Keith
Not sure about that exact spinner, but no Adaptor used, there is no thread on the shaft. You just require a allen head bolt, the correct length with a metric 5mm thread.
Screws into the end of the motors prop shaft. Nice a simple. Centre hole of spinner will also need to be drilled out to 10mm to fit over shaft.
Cheers
Scott.
