RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 12-06-2007 | 11:49 PM
  #659
dlenginesaustralia
Default RE: DL-50 engine
ORIGINAL: dlenginesaustralia
ORIGINAL: kcollier
Hey Guys,
I'm putting together my shopping list with DL50 at the top. Just wanted to know what size spinner adapter/nut is needed
to use with the Dave Brown standard 3.25 aluminum spinner or and any suggestions for a spinner / adapter combo?
Keith
Hi Keith
Not sure about that exact spinner, but no Adaptor used, there is no thread on the shaft. You just require a allen head bolt, the correct length with a metric 5mm thread.
Screws into the end of the motors prop shaft. Nice a simple. Centre hole of spinner will also need to be drilled out to 10mm to fit over shaft.
Cheers
Scott.
Just to clarify, the 10mm hole is drilled into the spinner back plate, not the spiner itself. And 4 x 5mm hole will also be required for prop hub bolts - just use the same drill jig as used to drill the props (DA-50 Jig)
[img][/img]
