RCU Forums - View Single Post - Nitro Models Kangaroo Modified
Old 12-08-2007 | 01:44 AM
BadSplice's Avatar
BadSplice
Default RE: Nitro Models Kangaroo Mods - Sheeting
Got a bit more done tonight. I think I'm pretty well done with filling and sanding the bottom. I will go over it with finer paper before covering, but the shape is nice and smooth.
I started in on the landing gear setup. Unfortunatly, when I tried to bend the wire for the mains, both of them broke before reaching 90*. Either I will get new wires, or the axles that slide on to the end of these, I haven't decided yet. Adding the curve to the bottom of the plane made a bit more room for the main Retract Servo, but still is a very tight fit. I took a pic of a standard servo sitting there, hopefully the retract servo is that much shorter. If not, I can carve a bit out of the last rib in the wing, and the corresponding hole in the body to make the wires sit higher.
ID:	820833   Click image for larger version
ID:	820834   Click image for larger version
ID:	820835   Click image for larger version
