RCU Forums - View Single Post - Skin Hinges,,, First Time Experiment!
Old 04-05-2003 | 04:56 PM
Bill Vargas
Default Skin Hinges,,, First Time Experiment!
http://www.rcuniverse.com/showthread...01&forumid=111
Howdy, here's a little more info for those that might want to try out the skin Hinge thing,,, but just aren't quite sure.
Experiment and Test with a scrap peice of balsa, some cloth, a peice of mylar, some 5 min epoxy OR with the epoxy that you are going to be using for the actual skin hinges on your wing. Mix a small batch of epoxy,,, lay the cloth down on the balsa and apply the epoxy. Next is to place the plastic over the work and squeegy out the bubbles and excess. Wait for this to kick off, about 5-7 mins and then just peel away the plastic!
Next is to flip the balsa over and cut a small groove, about 3/16-1/4 wide, to expose the bottom side of the fiberglass.
And there you have it,,, a fiberglass skin hinge
BVV
