RCU Forums - View Single Post - Skin Hinges,,, First Time Experiment!
Old 04-11-2003 | 07:48 PM
Per_N's Avatar
Per_N
Default Bill
I would give that a try but i don't think i have to little of epoxy resin. I have not use any mylar plastic to cover the glass when i put on the resin, so i think you will always see some of the pores anyway.
Have you or anyone else experience these kind of problem before?
When you grab the rudder you can move it up and down maybe 3-4mm each way.
I guess if i mount this and go fly with it, it will explode in air.
I can't understand how it should be possible to get this construction stiff, the only thing that is stopping the rudder from moving in this direction is some thin glass and a small TQ rod
Any help here would be nice.
Thank's
Per
