RCU Forums - View Single Post - how to make a 6 volt pack
Old 12-08-2007 | 02:12 PM
rctrax
Default RE: how to make a 6 volt pack
also make sure you understand what polarity is all about. To solder together indvidual cells to make six volts you need to solder together five cells positive to negative to end up with a battery with a pos and neg wire to hook to a connector to plug to the rx.soldering all po's and all neg's together would leave you with only 1.2 volts total
