RCU Forums - View Single Post - PERIGEE Prototype Kit Build
Old 12-08-2007 | 02:47 PM
  #80
BobHH
My Feedback: (18)
Default RE: PERIGEE Prototype Kit Build
After all has dried I cut the 3/32 balsa sub leading edge and add the preshaped trailing edge balsa. The extended tabs insure they are correctly positioned. After the have drier I lightly sand the top to remove any high spots. This I use a Great Planes 22 inch Easy Touch aluminum bar sander. I then temporarily tack down the sheeting drawings to the 1/16 balsa. Cut it out and install them on the wing.
Duane I want to supply these already cut for easy installation but that will be a Dan call. Anyway after the top sheeting is installed I install the cap strips. Now its time for the bottom of the wing.
Bob Harris
ID:	821188   Click image for larger version
ID:	821189   Click image for larger version
ID:	821190   Click image for larger version
ID:	821191   Click image for larger version
