RCU Forums - View Single Post - Pentathlon Kit Build
Old 12-09-2007 | 10:41 AM
  #49
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
The canopy sheeting is really not bad. However, the top pieces will take some patience. Wet those sheets and clamp if necessary.
I will final sand and fill the canopy later, when the rest of the fuse top is built.
Tape the canopy in place and begin work on the front deck formers. Use a sheet of wax paper to set the former that mates to the front of the canopy. With the foward front deck former in place (atop the firewall), the stringers can be added.
Sheet this with contest grade 3/32".
ID:	821874   Click image for larger version
ID:	821875   Click image for larger version
ID:	821876   Click image for larger version
