RCU Forums - View Single Post - grinding noise...
Old 12-09-2007 | 11:30 AM
Shadow99
Default RE: grinding noise...
FYI:
Be sure to check for MISSING TEETH on the main gear, when the brass motor pinion hits stripped-out teeth on the main gear while under-load it just strips out more teeth due to mis-engagement, so 4 missing teeth will turn into 6 to 8 missing teeth & so on.
There should be a slight amount of play between the brass pinion & the main gear, too much engagement results in excess friction, faster wear on gear, and reduced flight-time. Too little engagement will result in stripped out main-gear with any stoppage of rotor.
Rick
