RCU Forums - View Single Post - 9C--how to activate idle ups?
Old 04-06-2003 | 09:09 AM
joffacn
Default 9C--how to activate idle ups?
I just discovered how to do this, but can not get my Logo10 model in Aerofly to give -ve pitch so no inverted flight!!
Anyway.. go to advance heli menu thr-curve. Use the select button to go up to NORM and rotate the dial. IDL1 or 2 or 3 will show and then you can go down to MIX and change the INH to OFF. This then changes when you move the E switch. It enables the Thr and Pitch curves at the same time.
Jeff
