RE: YS HS setting
using a tachometer to read the rpm of the engine you can lean it slowly till the engine gets to a peak rpm then richen it up by 200-300rpm (1/8th turn) from this peak rpm position this is the best way to find the High SPeed needle setting.
Troy Newman
Team YS
