ORIGINAL: propnuter
Roly
About a tendency to be tail heavy, If you build the plane with fuel engine, I think you might be right. A few days ago I spoke with MONTEZUMA and he told me that he saw in the ARC version that CAMODEL placed the wing tube about 1 cm or so behind the mark on the fuse.
MONTEZUMA, it will be nice of you if you put here a picture of that.
Isaac Najary
Hi Najary,
I have a deluxe arf Osmose kit. I ordered the plane to suit a YS engine and two servos in the stabs.
The trailing edge of the wing is 1.5cm behind the rear mark on the Fuz. If your wing trailing edge matches the mark on the fuz then they are moving the wing location to suit the equipment used. If this is so then my CG will be on the wing tube ?
Shane
[/quote]
Hi Shane
The CG is always relative to the wing cord, if the recommended CG is 1cm behind the wing tube (So mentioned somewhere in this forum) so that should be the starting point. (Not on the wing tube).
Isaac Najary
