ORIGINAL: PatrickBW
Sorry, can't help ya.. I filled mine basically nearly to the top, so that they would still fit together without having oil goup out all over the place..
I didn't threadlock the screws though.. Is that bad??
And I have a new question too..
After MUCH fiddling, I think I got the gas/brake linkage sorted..
But now to steering - I just bought an alu servo arm for steering, but it's several mm shorter than the arm supplied in the box... What does this mean, and if anything, what should I do about it?? Thanks..
I had a problem with my hyper not steering lock to lock with the shorter steering arm and I have a spektrum with the settings set all the way up for most steering. I bought a longer one and now it is fine. The longer the arm the more throw it has to move the wheels more side to side.
