ORIGINAL: wolf65
Yeah, I checked it twice.
I used a Vess 22 B. Seems like a good prop. I had to sand a tip but only slightly. It holds at 11 and 2 positions so I think the hub is good although I didn't have to weight it.
I'll probably check it once more before the maiden flight.
Wolf, I don't like to sand my props, try a can of clear spray laq. (can't spell it but hope you get the idea) put the prop on the balancer and spray the up side. easy does it little goes a long way. If your not careful you will be spraying the other side trying to get it back.
