ORIGINAL: jnp
Isaac , I have not done much plug in wing installations on composite fuselages so your pictures are certainly going to help a lot when I finally get to build my Osmose . The only thing I find not too clear is the tempory spacing pieces of wood you stick to the fuselage with tape ...Why do you do this ? Is this to ensure you dont glue the wing panel to the fuselage when glueing in the tubes etc? Thanks Juan
Hi Juan
You right, that is the reason.
Isaac Najary
