RE: the hyper st PRO thread!
Yes that is correct. When you put the diff in the diff case the washer will be in between or sandwhiched by the diff case and the bearing. This is what shims it inside the case to the gear that the center driveshaft connects too. When the diff is removed the washer will fall off of the cup.
