RCU Forums - View Single Post - Can't get off the water with Float Plane
Old 12-13-2007 | 09:56 PM
simhatus
Default RE: Can't get off the water with Float Plane
Hi
I have had this problem and seen it on other planes.
The step is not always where it appears to be, put the plane on a flat surface with the wings level and see where the float touches it could be that it is in front of the actual step effectively moving the step forward when it is planing and not allowing it to take off.
If this is the case just stick a couple of wedge shaped bits at the actual step in order to make it deeper.
Simon
