RCU Forums - View Single Post - balsa usa phaeton 90
Old 12-14-2007 | 01:33 AM
  #43
whatwind's Avatar
whatwind
Default RE: balsa usa phaeton 90
Just an up date things to do yet. I'm trying to wrap the cabane and n wires like MJM did his .the easiest way I found to do this was to cut a piece of wood sand a grove into it wrap it with covering glue the wire into the grove then cover the exposed wire. for cockpit molding I took a spark plug wire cut out the wire painted it black works great but I still want something to trim the windsheld with. raido is in throws are set . trim, polit,aileron top to bottom link and engine run and set are all thats left. I have to say this was the easiest engine cowl i have ever fitted. post more pics soon thank you for your support
