RCU Forums - View Single Post - I Need Help Please Read
Old 03-04-2002 | 04:59 AM
mrtim-RCU
Default Here's the best I can do for you right now Buddy
Here is the best I can come up with David, I hope it will help out.
1. 4-way wrench
1. new bag of #64 rubber bands
1. new package of 3 feet of fuel tubing
1. .40 sized engine mount
1. package of 1/16th threaded rods with clevises (2)
1. set of allan wrenches
1. new Tower hobbies Glow PLug with Idle bar
1. new switch and charging jack mounting set
1. phillips screwdriver
3. props, 1 10x6 1 9x6 and 1 9x4
1. easy fueler fuel filler valve kit
4. 2 1/2 inch tires
1. fuel tank with hardware
3. older tower hobbies servos for Futaba
I wish I could do more for you, all I ask in return is that you pass the favor along when you are able to do so, be it helping out others at your field or giving extra items to someone else that needs them when you are able to do so.
I have it boxed up and ready to send, I will send it out tuesday morning.
I hope this helps some.
