RCU Forums - View Single Post - when is time to push it more?????
Old 12-14-2007 | 11:25 PM
BryFlyGuy67's Avatar
BryFlyGuy67
Default RE: when is time to push it more?????
ORIGINAL: matador_24
Thanks, I understood, just one question more, I have a DX7, according with Bob finless videos... it's good for a beginner to set the swash mix at aileron 35%, elevator 35% aprox., if it's increased to 50-60% or so, the swashplate is more sensitive.. is it right???? at this moment my set up is ail 35%, elev 35%..... should I increase it to 50% in both in order to do the loops and rolls or better to keep it that way????? what is your set up in that????
Thanks...
As per Jermo's videos on the DX7, you should alwys start with the default values of 60% for elevator, aileron and pitch. If memory serves, that is the setup that I am running and I get +/- 10 degrees pitch with no binding. I think that Finless uses a Futaba in his videos, so it's different.
