RCU Forums - View Single Post - Explain how a Hayes fuel tank is hooked up
Old 12-15-2007 | 04:55 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Explain how a Hayes fuel tank is hooked up
The Hayes tank is not set up to lay on its side, which it what you want for an installation inside a wing. The pressure line is molded in at the top of the tank so it will be halfway down if you lay it on its side. It will work, but it wasn't designed for this. You really need a Sullivan or DuBro. The Hayes works best in a vertical mode, like on the side of a prifile.
