RE: will this work?
That JR is one of the best. Have no worries about it.
When you're about to install the battery and RX, check the CG location with them just sitting where you think they should go. If the CG isn't where you want it for the first flights, them move the battery around to set the CG. THEN install it.
Checking the CG while installing always saves you time.
