RCU Forums - View Single Post - Tornado Problems
Old 12-16-2007 | 01:10 PM
xjedix's Avatar
xjedix
Default RE: Tornado Problems
Thank you for the input. I just got done adjusting the throttle linkage. I ended up moving both rod stops towards the carb and put a bit more tension on the spring as suggested, it appears to have fixed the throttle slop. I also did the paper clip mod to hold the pull start out of the way of the linkage. I will get it fired up in the next few hours and post results.
Quick question about tire/ suspension combo. I will be racing 95% on the street and was thinking of tweaking the tire/ suspension combo to make it stiffer and lower to the ground. I was thinking of going with a standard streetcar rim and tire combo and get some stiffer springs, will this produce the desired results or is there more to it?? Any suggestions are welcome.
Thanks again for the help,
-Derek
