RE: Rx antennas: can I do this?
If you give it a good range check (truly as far as you intend to fly) then you can get by with it. You will suffer a range loss relative to a properly mounted antenna, at least 50% or more. Check out rc-cam's web site for some good info on how antenna changes effect range. Even the best designed shortened whip or best engineered coiling will positively reduce the range over what a normal installation will have.
