RE: Tornado Problems
**Update** I just ran a tank through the car and the throttle linkage problem is fixed. It now idles perfect and drops to the same idle with full brake applied. The only issues I am having is a little bit of a sluggish start off the line (I assume its just the clutch engaging slow) and the shifting. I have not heard a distinct shift since I got it new. Should the sound of it shifting be obvious or is it hard to hear the shift?? I have not touched the shift point adjustment at all; is it possible that it was not set correctly from the factory??
-Derek
