RCU Forums - View Single Post - ys 110fz s with big problems
Old 12-17-2007 | 08:58 AM
marzini
Default ys 110fz s with big problems
hi troy
i still haveing problems with my ys fz110s im using 15% nitro, 20% oil , os type f , apc 15x8
the problem is that i can set tehe ngine to run ok, i start the engine and the rpm goes hight alone abot 6ooorpm with full trothle close, and then the engine stop , i styart again an d the same problem , i put full trotlhe and teh engine works very erratick, also adjustin the hight speed needle , i want to nowk how to dismbly teh regulator to clean because i think taht there is the problem, the low and hight speed needle are in factory pre set
thanks
marcelo
