RCU Forums - View Single Post - Rx antennas: can I do this?
Old 12-17-2007 | 10:07 AM
Rodney
Default RE: Rx antennas: can I do this?
If you want some good info on antenna effects check out http://www.rc-cam.com/ant_exp.htm. You will see that even the best shortened whip will cause an 8 db loss. Remember, the range is decreased by half for every 6 db loss in signal strength.
