RE: Site Changes Causing IE6 to Hang
Ditto here too! It is almost impossible to use RCU forums as each one takes 10 minutes to load (if it ever loads!). If it does not load then IE6 crashes after about 10 minutes. It will start to load then just hang then not repaint the screen. If I have something else open (Outlook Express) then that something also has trouble painting the screen as IE6 is using all of the system resources. I do not use Firefox or IE7 (nor will I use IE7).
I am using a P4 2.4ghz desktop.
I also notice the VERY ANNOYING POP-UPs if I go to my Inbox and look at a PM (if I go directly there then it loads but forums are impossible!).
I first noticed it with messages last night. I do not know what was done on the system but it is vertually unusable for me!
