RE: Panther Tail Pipe Location
It is a Fei Bao Panther.
Yes I decided to not use the bypass included in the kit. I like open systems. Never had a problem with my jets since I wrap the fuse in BVM Heat Blanket and Aluminum tape all the way around where the gap between the pipe and turbine is. Also with the Panther I can taxi with the inner flaps (under fuse) down opening the fuse for cooling if needed.
Thanks guys!!
Dom
