RCU Forums - View Single Post - those prop changes
Old 12-17-2007 | 09:12 PM
suzonka's Avatar
suzonka
My Feedback: (7)
Default RE: those prop changes
ORIGINAL: ADChobbystore
Yes, you should still be able to throttle back at times to conserve battery juice. The main difference you will notice is that you will have to have the throttle up a little higher on the stick, but it basically all balances out, since the prop. will be a bit smaller and most likely pull less amps than the 9x7. Your flight times will be relatively close to what you are getting now, they should be a tad longer due to less current draw.
Thanks again .
