RCU Forums - View Single Post - O.S. .61 FX Engines
Old 12-18-2007 | 04:35 PM
linkadrip's Avatar
linkadrip
Default RE: O.S. .61 FX Engines
ORIGINAL: proptop
Link...I picked up a few r.p.m. by rolling the lower lip of the ports on the outside of the sleeve.
I don't think aircraft engines turn enough r.p.m. to make all the other mods typically done to r/c cars engines worth while?
The tuned pipe will give ya a boost in top end at the expense of throttlability through the mid range, so it's a bad choice for 3D style flying.
I tried it a couple of times with 2 different .46's and pipes went back to a Tower/Aquacraft muffler.
Any good quality 10% nitro fuel w/ maybe a few oz. of extra Castor mixed in will work...and mine likes an O.S. #8 plug...and maybe you could use an 11 X 7 for break-in before going to the 13 X 4W for flying.
Hmmm rolling the lower lip of the ports on the outside of the sleeve, So that is taking the edge off the ports buy filing them down how is this done? Sounds intresting proptop
