RE: O.S. .61 FX Engines
From my experience with die grinders, the technique is somewhat different than what they posed for the pictures.
It is best that the sleeve or the Dremel be held securely so it cannot move.
The other device must be held steady with both hands.
If you do not follow this plan, the Dremel will take off across the sleeve and embarrass and/or hurt you.
