RCU Forums - View Single Post - Electric Osmose Building
Old 12-19-2007 | 03:00 PM
  #115
najary's Avatar
najary
Default RE: Electric Osmose Building
ORIGINAL: jnp
Hi Isaac , from your pictures please clearify the following for me on the Belly pan attachment . What are the little black squares on each side of the locating pins ? On the front of the Belly pan you have a small bolt - are you going to use this to bolt the Belly pan down through the air intakes you made in the Belly pan ?
Juan
hi Juan
The little blake spuares are soft sticker which I use to prevent contact between the belly pan and the fuse (see picture).
Yes I am going to use the air intakes as an access to the bolt.
Isaac Najary
