RCU Forums - View Single Post - setup problem on slowstik
Old 12-20-2007 | 04:37 AM
sowega flyer's Avatar
sowega flyer
Default RE: setup problem on slowstik
I use Deans T-style connectors. Put a male end on your charger and one on your ESC. Put the female end on the battery. Always use the female side for the battery, and make sure the solder connections are protected by heat shrink tubing.
http://hobbypeople.net/gallery/625085.asp
You'll need 2 sets in order to get both male connectors.
