RE: setup problem on slowstik
does your charger have the balance charge plug? I like the Deans connectors as well no problems with them od solid connections. As stated above, always put the female connector on the battery side. The bullet connectors go from the motor to the speed control. are you going brushless with your set up? On your battery charge with the ballancing jack and not with the power jack. you battery will not last long the other way. I learned that the hard way.
