RCU Forums - View Single Post - Fueling Valve
Thread: Fueling Valve
Old 04-10-2003 | 06:18 AM
Dauntae
Default Fueling Valve
Originally posted by Stang
"Add a third line to your tank and connect it to one of these:
You pull out the dot, and the line comes out with it. Remove the Dot from the line and fuel/defuel. put the dot (plug) back in the line, and place it back in it's hole."
MinnFlyer,
Could you explain further on the setup of fuel dots. Your pic show's (2) fuel dots. You have mentioned adding a third line.
1 line to the carb
1 line to the muffler
1 line to the fuel dot
Not sure what is attached to the second fuel dot in your picture.
Roger
on the instructions for my slimline dote it tells you to put the other one on the exhast line with a "T" so when it fills the exess goes back into the filling bottle, instead of dripping through the muffler but it has to be mounted below the muffler.
Dauntae
