ORIGINAL: Farmer Ted
WOW! Thanks da Rock... That's awesome information. I will take a look at the plane and see if I can make your modification with some confidence (I'm sometimes unsure of my modeling skills...more confident in flying skills at this point. )
It's actually pretty easy to do. And if the airplane is already setup, all you have to replace are the top aileron horns.
What the job amounts to is cutting a slot into the aileron the width of the top part of the aileron horn. You cut the base off and use just the top part. Epoxy that part in and it's done for the bottom aileron. Almost done for the top. For the top, you have to remove some aileron TE so the pushrod doesn't hit.
Pretty simple.
