RCU Forums - View Single Post - Tornado Problems
Old 12-22-2007 | 09:55 AM
tklemin
Default RE: Tornado Problems
I have a bb pro, and found that the throttle stop closest to carb was hitting the servo link( not sure what its called). It should rest against the loop attached to the servo link. I touched it against a grinder to make a little notch so the stop hits the loop( not servo link). It allows just a little more adjustment. Also make sure that the screw attached to the slider that rests against stop is tight.
